Biasi B10 Boiler Bypass
Bruce M.
Member Posts: 143
Is it needed or just a good idea. Best way to pipe.
Trim
This is close
al0 -
Solia
Thanks. What is a Solia?0 -
No mention in my B10 manual
of any bypass piping. The B-10 used to be called the Vega.0 -
Biasi
Solaia vs B10
Nice pic eleft, and it is a "Biasi" casting; it is not the same design as the B10 casting. With that in mind( I won't use the HST phrase), the Biasi B10 manual does not mention any need for a bypass. The GG20 iron will take low temp return water. Flue gas condensation protection depends on the system design, and should be built in as appropriate.
Jed0 -
Call to QHT indicates bypass is needed
I called QHT and they indicated that a bypass is only needed when a certain amount of radiation is exceeded. However, they left me with the impression that it is a good idea in any case.0 -
never
had a need,tough little boilers. Dave0 -
Looks Alike
never
had a call for it,tuff little boilers.Done a couple with large water content with no problem.Heres a small one. Dave0 -
never
Installation
Dave, I've got to talk to you about the burner you've got on that boiler.
Thanks Eleft for the info
Can you please post the other pages of that Solaia manual?0 -
you'll be happy too hear I'm doing one tommorrow with a Reillo,hope I don't have problems,Dave it was hard mounting the boiler like this0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
