patterson kelly
Rick_19
Member Posts: 3
Anybody recommend a manometer that will read 1.4 .My basic guage does not read that low.
manometer that...
I use is a regular, old U-tube the bachrach with blue fluid. Just recently I was starting up a burner and used a dial type and had trouble reading the manifold pressure accurately, when I called the mfg for help he told me to throw that @### thing away! Using the u tube I was able the read low enough and to follow the rise in pressure throughout the firing range. It saved me alot of time.
Best regards,0 -
A Dwyer Slant Gauge
check at www.dwyer.com.0 -
Best bang for the buck,
Dwyer 1227 dual inclined manometer.
"Use Series 1227 as a regular U-tube manometer to read high-range pressure on the right leg, or as an inclined manometer to read low-range pressure on the bottom leg. Simply incline manometer until fluid levels read zero. No spirit level required. Magnetic clips hold the gage in position on a steel duct surface.
Most versatile and useful low cost manometer we know of. Designed for installation and servicemen. A sturdy, clear plastic manometer, it offers single, direct readings in two ranges: As a U-tube, it reads from 0 to 16" of water; as an inclined gage, it reads from -.20 to 0 to 2.6" of water. Model 1227M (Metric) is 0 - 400 mm water column as a U-tube and -5 to 0 to 70 mm water column as an inclined gage. "How-to-use" instructions are printed directly on the scale."
http://www.dwyer-inst.com/
http://www.dwyer-inst.com/htdocs/pressure/Series1227Intro.cfm0 -
perhaps .....
it's time for a quality DIGITAL instrument ....0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
