air vent
Rick_19
Rick_19 Member Posts: 3
Anybody use the spirovent air vents .Have job with boiler on top of bank vault. Past installer did not install any air vents or air scoop .This boiler heats two hot water loops .Looking for good vents that will not leak is that possible.
  • al leone
    al leone Member Posts: 25
    Spirovent Air Elinemators work really well, the ones Ive installed never leak and the get all the air out.
  • Weezbo
    Weezbo Member Posts: 6,231
    Spirovent :)
    you can pipe away from the spirovent to a drain also....1/2" ...just a suggestion.
  • Rick_19
    Thanks for the help.
