Look what I found (radiant)
Ted_9
Member Posts: 1,718
Went there for a service call. Check out what someone did. Basement slab install only. The rest of the house is high temp.
PATRIOT HEATING & COOLING, INC.
Balanced flue
That Odyssey is a nice little boiler - Oil fired, cast iron and will accept return temps down to 90F. The fill and expansion tank placement are questionable but the 3-way thermostatic should work fine. What was the problem? Dan
Since I didnt install this and I havent installed this brand, I went online to find some info on it and its microprosessor.
I didnt find much but I did find a piping diagram that shows a boiler by pass so I questioned its ability to handle the low return temps. Does it have "pump logic"?
I also think its a Caprice, not the Odyssey
PATRIOT HEATING & COOLING, INC.0 -
thats an Odessy ....
for sure..nice little unit. I want to try one soon. It has outdoor reset standard. What % is the radiant to the heatloss? How was it piped to the zone any mini primary/ sec.? kpc
NTI
The "caprice" is a packaged steel with top flue. What you have is the "odyssey" cast iron. The casting I believe is Italian and carries about 5 gallons of fluid, the control is NY's Sentry - the same control type as they use on the Trinity with different programming. Comes complete with outdoor reset and the control handles both heating load and priority DHW indirect. Enjoy....Dan
Great then. No worries.
Tulips
The Tulips next to the boiler are a nice touch!!!0 -
Signs
I'd like all those arrows sticking to the pipes to tell the water what diretion to flow.....Dan
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
