Tankless Heat Question
Joe E
Member Posts: 2
My radiators get hot even when the heat is turned way down. I have a tankless heater system, and suspect when the hot water is demanded, some is leaking past the check valve and warming the radiators. Does this explain why I would have a warm house, when the heat setting is below 60 degrees, and it is 45 degrees outside?
Is that to say ?
That your domestic and heating system water are comingled ?
You are about to get "educated". Hang on to your hat and pay attention, the information you will surely get could save your life.0 -
It is a tankless system, they are not mixed, they just share the same boiler heat source.0 -
okay
I jumped to a conclusion. Sorry.
Sounds like you have "ghost flow". Probably improper piping. Can you post a picture ? Or a detailed description ? (Pics may still be needed)0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
