adding radiant floor heat to a monoflo system
Mijola
Member Posts: 124
is it possible to add two zones of radiant floor heat to an existing monoflo system?,and how.
mono flo system
is it possible to add two zones of radiant floor heat to an existing monoflo system?,and how.0 -
radiant with monoflow
Sure!!!! Why not!!! Just consider each portion of the system as a separate zone and protect each zone with a flow check and you'll be OK. As to how? It depends (don't you hate that expression?. but it's true) on the size, load, flow rate, control strategy and so on. Make sure the boiler can handle the extra load and set it up any way you wish. Probably using mixing valves will be the easiest and going primary/secondary the hardest, but enjoy the challenge. If you're a homeowner, get in touch with a pro to do this work.It's not all that easy.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
