3 OF 7 NOT HOT
COOPER
Member Posts: 1
HELP !!! 3 OF MY HOT WATER RADS ARE NOT GETTING HOT. TRY TO BLEED THEM AND COLD WATER COMES OUT. WARM WATER OUT OF ONE. THERE IS PRESSURE AND WATER GETTING TO ALL OF THEM, BUT THESE FEW ARE NOT HOT -- AND THE LEAD PIPING TO THEM ISNT EITHER.
IS IT POSSIBLE THERES AN AIRLOCK IN THE PIPING?
ANY SUGGESTIONS ARE GREATLY APPRECIATED.
THANKS, COOPER
THANKS, COOPER
I think it is possible that your CapsLock key is stuck.0 -
Water pressure
When I see this and it's often unless there is a bad zone valve or pump the problem is water pressure. Go down the basement and make sure the gauge is at least 12# cold, put in water to 14# to make sure the gauge works.0 -
Sounds more like...
a flow problem than pressure - he's got water at all the radiators. Are the cold rads on a different zone? Or some could be getting heat just from gravity flow, if a pump or zone valve is no good. Be careful not to add cold fill water to a hot boiler that could be way low on water, if it is pressure (let it cool)!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
