insulation for 2 pipe steam system
gfe76
Member Posts: 1
I have a 400,000 btu steam 2 pipe system. removed all the asbestos insulation from exposed pipe in basement. what should I inuslate it with? 1 1/2" thick or thicker? should I insulate the exposed returns? should I inuslate the couplers and the valves? thnks
1.5\"
The 1.5" fiberglass works nicely. Insulate everything you can get to that is above the water line, including the unions, 90s, 45s, and anything else. I haven't insulated my wet returns at all (above the water line) since I like little heat in the basement.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
