Buderus Install Help
RoosterBoy
Member Posts: 459
hay guys my HVAC crew was here just set up my boiler and lt 160 out of the box and in place and planning the piping layout with me.
this is there first buderus install but they are very smart and you will see that when you see the pictures of the job when it's done
the rack that the lt tank has for the g115 model 28 to sit on should they have installed the rack on the tank first and then dropped the boiler on top of the rack and slide the boiler back to the first hole on the rack?
we can still do this in the morning if you guys can just give me a tip for them on putting the g115 on top of the tank. the instructions were very vague on this it just showed feet and if your putting it on top it shows a rack
thanks guys
i just painted my zone panel for them tonight :-)and should have pictures soon
thanks guys
Rooster
not trying to sound cocky...........hehehehehe :)But cut and paste this link.Go to page 9.I'm guessing you can probaly read your instructions on page 9.To me it is not vague.......seems pretty specific and easy.I know I've hoisted several myself:).
Enjoy your new system!BTW I liked your tank install:)
cheese
http://www.buderus.net/Portals/0/Lit-G115-IOM-01.pdf0 -
i like that mike good one cockey :-) hee hee
mike I found the problem I have the new manuals that are different from the one you gave me mine where done in 2004
I will print this one out for the guys tomorrow :-)0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
