Need help Finding
Craig R. Bergman_2
Member Posts: 8
We have a customer looking to add a little floor warming to the tile areas of his house. the max BTU/HR needed will most likely be around the 40,000 range(just a quess for now.) What types of tankless have you guys had good luck with??
Thanks;
Bergy
Thanks;
Bergy
Poor Application
Tankless water heaters are ONLY water heaters. Especially in the lower output ranges they are near useless for radiant floor applications. By design the tankless requires high temperature rises on small volumes of water while the rsdiant panel requires small rises in higher volumes. For your +/- 40M design load you should be looking at a 12KW boiler. If electric is your passion there are several great products out there to choose from. Enjoy....Dan
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
