Angle Valve RetroFit
tom_54
Member Posts: 46
to retrofit a steam supply angle valve to have a main vent come off the top instead of a handle?
Any
ideas?0 -
remove valve,replace with tee [full size or reducing heel ]install vent in run of tee and provide steam radiator gate valve w/ union spud tailpiece and reconnect radiator.0 -
thanks...but
I don't have the room to move the radiator over to add the extra valve. Any other ideas?0 -
yea .....
forget it ....0 -
besides ....
a Main Vent .... belongs ... on a Main ...,:-(0 -
You could
orient the bull of the tee away from the wall and install a close nipple in it, then screw the existing valve onto the nipple with the union pointing toward the radiator. Then hook the radiator up in the usual manner. The radiator will sit a bit further out from the wall but you won't have to move it to one side.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
