RICHARDSON BALL CHECK ELLBOW
BOB_3
Member Posts: 8
I RAN INTO A VACUUM STEAM SYSTEM THAT HAD RICHARDSON BALL CHECK ELBOWS ON THE RADIATOR RETURNS. I HAVE TO REPLACE ON ONE THESE RICHARDSON ELBOWS. ANY SUGGESTIONS?
Use
a thermostatic radiator trap.Retired and loving it.0 -
Is it possible Dan
to just change the balls? I had one where a few of the rads had the balls missing as the painters removed the radiators. I had them measured and my machine shop buddy ordered me a bag. Is that considered o.k. if the ell fittings are in good shape??? Should I just have added the rad traps instead?0 -
You bet.
As long as they're the proper size.Retired and loving it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
