1 quick question-water gauge valves releasing steam
John MacGregor
Member Posts: 41
Hello,
I know that this probably isn't a tough question for you all but given that I haven't received my copy of Dan's book yet...Just noticed that steam was coming out of the valve at the top of the water gauge (1 pipe, gas powered steam heat for reference). Is that normal?
I checked and the bottom valve is closed while the top one is completely unscrewed - Is that how they should be set?
Thanks for all your help guys - your expertise is invaluable!
~Jenny
~Jenny
Both wide open
Only close for service or broken glass (emergency only, fix right away)
Noel0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 65 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
