Should I shut down boiler
Ed_5
Member Posts: 24
I have a Burnham Series 2 boiller located in the basement and I'm having my harwood floors(first floor)finished with oil base polyurathane. Is it recommended to shut down the boiler because of the fumes? Thanks for the advice. -Ed
Shutting off boiler
Shutting off boiler
YES
Shut it off, do not let the boiler operate while the floors are being finished. Also, ventilate the building properly and do not leave any other ignition sources present.
If you are doing this yourself, contact the manufacturer of the finish product that you are using for guidlines and details. READ and FOLLOW the instructions on the finish product that you are using. This is no joke.
See link below
http://www.forumworld.com/arson-investigations/search.php?f=1&search=Floor+Finish&match=1&date=180&fldsubject=1&fldbody=1
Ed Carey0 -
floors
turn off gas to stove,waterheater turn off boiler for saftey sakes ventalate building while applying urethane and afterwards
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 65 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
