Hot H2O Coil from steam boiler
Firedragon_4
Member Posts: 1,434
or even better a convertor.
Go here:
http://tfi-everhot.com/pdfs/TFI_ExternalTankless.pdf
Go here:
I,m a HVAC contractor hired to install a Hydro-air zone into a new addition off of an existing kitchen.My load is close to 40K BTU/h needed.The only heat plant is a steam boiler,capacity not sure.Can a loop of hot water be used from this boiler for the new Hydro-air fan coil unit effectively?0 -
Yes
I wouldn't use a heat exchanger, though. I'd do it like this.
http://trainingroom.slantfin.com/articles/nm0304-1.html
Noel0 -
Steam boiler to H2O coil
Thanks for the great INFO,Firedragon & Noel,much appreciated.0
