Pictures of Ductile Iron on boiler outlet. Opinions please?
D. McLean
Member Posts: 20
I posted this a couple of weeks ago, without pictures. I have never seen ductile iron on a hydronic system, and need a definitive answer on whether it will stand up to the temperature fluctuations, etc. Any opinions out there?
D.McLean
D.McLean
Nobody
Interested? Or is everyone stumped by this question?
that's a new one...
on me...What is the operating range of the system? (press. and Temp.) Long term I would wonder about the cement lining. kpc
hey
What is the problem ?...IMO it is the best stuff going. Do you have gasket issues?0 -
Ductile..
The installers probably had the stuff hanging around. I think extreme temperature swings would be bad but if the ph is ok, it will probably last 100 years. Robert O'Connor/NJ0 -
seen it
I have seen it done on a number of commercial application's. As far as I know they are still running strong.0 -
is that ---CL54 i did a job replacing the grit lines of a treatment plant with that ---that is some heavy duty pipe --if its CL54 you will have problems with the lining of it0 -
Pressure
Pressure operates about 30 PSI. Relief valve on boiler is 40 PSI. Boiler will operate about 140-160 degrees.0 -
Boiler
Boiler was installed last spring by others. I am not familiar with this type os pipe, and the majority of people I've asked, say it has to go, cause it will not withstand the temperature fluctuations. Our company recommended to the bldg. owner that he have it replaced with blcak iron.0 -
ductile Iron
I have seen steel pipe with victaulic fitts before, but gas selection must be right, also I mostly see these on lower temp heat pump loops with reheat boiler. I would really question the ductile pipe.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
