Wirsbo Actuators
Rick_18
Member Posts: 12
I have installed on my radiant floor system a TruFlow manifold system. I have purchased the Four-wire motorized valve actuators for my zones.
The problem I am having is trying to install the actuator on the brass threads. The pin on the manifold does not seem to push down far enough for the actuator to reach the threads.
I have used brass manifolds with no problems. Is there a trick to install the actuators on the TruFlow manifolds?
Are they powered or in the call for heat position?
Did you install.........
the adapters?There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
