Finding a professional in Jacksonville, FL area
ombre
ombre Member Posts: 32
Back to my daughter's 40 year old gun fired warm air oil furnace-----
I would like to have my daughter's furnace tested by a professional oil technician. For draft, for CO2, for smoke, primary air setting etc. etc.
I used to do it years ago, although only occasionally. Could do it myself still today with a little refreshing from my old 2 inch thick NOFI tech manual. I could relocate the tech manual, but I no longer have access to any test equipment. Don't think you can rent that kind of stuff. Or can you?
I don't mind paying for a professional to do it. (or more likely my daughter paying---she makes more than I do)---
Trouble is I checked using her area zip code for the "search for a professional" on this site---and came up nada. Not within 100 miles. Nada.
Is that a mistake? Nobody even within 100 miles of the Jacksonville area servicing oil furnaces could do a proper test and adjustment of her furnace? There are no pros in Jacksonville?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,618
    Hard to believe, isn't it?
    Opportunity knocks. Any pros listening.
    Retired and loving it.
  • dconnors
    dconnors Member Posts: 215
    Local Wholesaler
    try contacting a local supplier of heating equipment
  • John Conway
    John Conway Member Posts: 64
    All Pros Bulletin
    To all pros out there:
    How can we homeowners find you if you don't identify yourselves?
    I've wasted loads of dollars on hacks, I'd much rather pay for knowledge.
  • Ranger
    Ranger Member Posts: 210
    Hum....
    Much to my suprise there is a fair amount of Oil fired equipment in Florida but all that I have seen is commercial/industrial (DHW in hotels and big steam generating plants) so I would try a Commercial/Industrial contractor and explain your situation.I'm guessin' thay will understand your dilemia.:-)
    P.S.,The closest contractor I know of down there is in Savannah Ga.(Coastal Air)
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    That's little closer
    Than I am.
    I'm in the Atlanta Georgia area.
    Jeff
  • Ranger
    I thought about you...
    ...for about a second there Jeff but Jacksonville's gotta be at good 6-7 hour run from your local,right? Hope all is well with you and the family.
    Ranger
  • Robert O'Connor_6
    Robert O'Connor_6 Member Posts: 299
    Is there
    much oil heat in Atlanta?
    Regards
    Robert
    ME
  • Mark R.
    Mark R. Member Posts: 40
    Try this site
    Ken, try this site http://hvac-talk.com/vbb/ and scroll down to the residential foruma nd ask if anyone is in your area. I dopn't think you need to register to use it. Good luck, Mark R.
  • Jeff Lawrence_24
    Jacksonville
    Ranger, you're about right for the distance. The family is doing fine. I still kid with Linda about her purchases in Providence, having to buy (and check) a new suitcase.
    Robert, oil heating around here is drying up. I personally haven't touched oil in over 16 years and really don't miss it. We have natural gas, propane in more rural areas and heat pumps.
    Jeff
  • Robert O'Connor_6
    for the reply Southern Man!
    Regards
    Robert
    ME
    Ps Oil is huge here about 90%
  • Dave Bush
    Dave Bush Member Posts: 155
    Ken?
    Are you "ombre", that was at HVAC-Talk?
  • S Ebels
    S Ebels Member Posts: 2,322
    Mr Edwards
    For a nominal transportation/mileage fee plus room and board for a couple months, I'll come down from Michigan and fix it for free!!! (grin)
