Expansion tank
john_57
Member Posts: 2
I replaced a circulation pump on my system because it was leaking. I was unable to find a professional in my area to do it. I now have heat and it is not leaking but my repief valve builds up pressure. Do I need to do something with the expansion tank. Does it need to be drained or filled. There is not a drain on it but on my boiler on the same side is a circular hole with a plug inside. Should I unscrew the expansion tank and empty it? Next to it is a valve with an adapter on top that has threads in it and next to that is the relief valve. Help
Anything and everything you ever need to know about ...
Expansion tanks can be found at the following links.
http://contractormag.com/articles/column.cfm?columnid=45
http://contractormag.com/articles/column.cfm?columnid=60
http://contractormag.com/articles/column.cfm?columnid=75
If this doesn't answer your questions completely, feel free to check back later:-)
ME
