PAP for Snowmelt?
Are there any reasons why not to use PAP for snowmelt?
Just wondering what could happen to the composite pipe if the antifreeze mixture went unattended and a deep freeze were to occur. Could the aluminum layer breach if it got cold enough? If so, there is no memory for PAP and this could be a huge problem.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Other than...
the possibility of a complete tube closure from inadvertent pinch off when the heavy footed concrete guys are stepping on it as it crosses rebar, no...
I prefer good ol' PEX where its going to be abused.
I prefer viagra pipe when doing staple down. It STAYS where you put it.
ME
Why not
ME has a good point about rebar, it does pose a pinch potential.
Although I've yet to see a driveway here in Missouri with rebar used in the pour?? And the only reason you'll see mesh, in driveways, is if tubing is installed!
hot rod
freeze & burst
Isn't it possible that the PEX-AL-PEX could burst under the snowmelt? Let's say the system fluid was diluted down to just H2O. I see the pipe expanding and bursting. Is it possible?
You betcha...
and I've seen the same thing happen to regular PEX too. THe key to this problem is NOT providing a means of dillution to the equation. NO FRESH WATER MAKE UP ON ANY SNOWMELT SYSTEM period.
Use the PIG...
ME
Ahhhhh,,,the P.I.G.
Pressure induced Gizmo.;-)
I've not seen (or heard) of PEX A damaged by freezing. However, I'm sure it has.
I'm just wondering if PEX may be the better choice for snow melt. I know someone who just placed a HUGE order for 5/8" Multicor for a melt job and I proposed the thought that composite tubing may NOT be the best choice for these systems.
PAP
We use PAP 3/4" always for snowmelt. It has a much larger ID than pex. We run 300' loops of 3/4" and have never had any problems. Larger ID means less restriction of this sluggish fluid at single digit temps. At least that is my rationale. W ran out of PAP so we used 3/4" pex-a. It got loose and put a golf ball sized goose egg in my helpers forehead when the tube whacked it. 3/4" pex has a lot of potential energy in it's memory.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
