TRV for Single Pipe Steam System
Jon Jakes
Member Posts: 2
Which TRV would you recommmend, for a Single Pipe Steam System in a large one family house. Manufacturers and where would be the best place to buy it, on the Internet or in the NY Metro area?
Thank for your informative web site!
one pipe steam valve
use the Macon # OPSK, comes with a valve , vent, vacuum breaker and t'stat. be sure to keep boiler pressure maximum 1 1/2 psi and cycle system to an off every now and then and you'll be delighted.0 -
use a thermostatic vent don't use a thermostatic valve.0 -
TRV
I've always wondered how there things work if the sensor is right next to the radiator. How can it possibly be accurate?
Thanks,
Chris0 -
Thanks for your help!
Jon0 -
Danfoss
Danfoss makes a vent, valve, and operator for 1 Pipe Steam. Available at most plumbing and heating distributors in NYC.
bb0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
