Buderus POST PURGE
RoosterBoy
Member Posts: 459
Hi I have a buderus G115 28 with a power Venter and was wondering what buderus recommends right now the powervent has a post purge set to 5 mins is this ok or should we up it to 10 min
thanks
thanks
Hi,
What burner are you running? Sidewall vent or vertical vent?
Ron0 -
im runing the riello 40 f3 with a swg-5s power venter
http://www.fieldcontrols.com/swg.html
it's a sidewall0 -
I'm surprised that you are not running a BF3. It would directly side vent if you aren't too far from the wall.
I run a 2 minute post purge on my G115/21 with a BF3 and about 7 feet of vent.
Ron0 -
yea I just think that a power Venter was nicer and that it will hold up better in the wind i had a power vent on my furnace for 5 years with no problem
I just bough this one with this new boiler and I got it in stainless steel
hay ron id love to see a picture of your setup with the bf3
thanks0 -
Hi Roosterboy,
No Pictures allowed until I clean the crap out of the basement. ;-)
Ron0 -
Post Purge
A two minute post purge will be sufficient to pull the gases out of the boiler and cool down the head of the burner.0 -
Come On!
your basemnt CAN'T be any worse than any of the ones we have seen here. kpc
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
