A/C Armstrong replacement coil?
Ted_9
Member Posts: 1,718
Anyone know if there is a replacement for the HT413-1 Armstrong cooling coil?
Im looking to replace one for a customer. If not I'm proposing to replace the air handler.
PATRIOT HEATING & COOLING, INC.
Armstrong
I'm sure there is. Get a hold of your Local Armstrong supplier. If they can't get exact part they should be able to get something that will fit and work. Otherwise,contact Armstrong directly. Is the unit newer? If so, you can also try Lennox. They own Armstrong and many of their parts are interchangable. P.S., Are you the same Patriot H&C from Bucks County?0 -
Hey I m a Lennox dealer and I didnt know that about Armstrong. Lennox used to have a flat coil.
We are Patriot out of Massachusetts.
PATRIOT HEATING & COOLING, INC.0
- 120 Geothermal
- 394 Solar
