Loud oil fired Burnhams
Paul_33
Member Posts: 3
I have installed 4 BURNHAM V83's and V84's the only complaint is they are loud when the burner is running. Any way to quiet them down?
Noise
Which tube kit is on the burner? 8 hole or 16 slot. the 16 slot is quiet.
al0 -
Paul
This question comes up once in a while and here is an explanation. The noise you are hearing is combustion noise and it does not happen on every installation. We arranged a few jobsite visits with some technicians from Beckett earlier this year and as a result of those visits Beckett reconfigured the AFG for the V83 and V84 with a 16 slot air tube assembly versus the 8 slot model. This changes the way the air flows around the head and has made a world of difference.
Other things that can inprove the sound resonance you are hearing is to move the barometric farther away from the boiler or closer to the chimney. Having the barometric opening pointing out towards the room or open space instead of toward a wall in close proximity will lessen the sounding board effect a bit. Hope this helps.
Glenn Stanton
Burnham Hydronics0 -
how about the V82
we have installed 2 and both customers have been concerned about the noise. marc0 -
There's a thread on this at OTT, too!
www.OilTechTalk.com0 -
Marc
I am not sure if this has been addressed with the V82 as there aren't too many of those out in the field. Due to the lack of a combustion chamber in this model, this one runs with an entirely different tube and head assembly. I will check with Beckett this week and see if that has been addressed.
Glenn0 -
Loud Burnhams
Will the newer 16-hole on the AFG work in the Burnham V74T boiler as well? like less noise.0 -
Fred
You will have to check with Beckett on that one. I do know that they have made a tremendous difference on the V-8. The V-8 uses the M series Tube though where the V-7 did not.
Glenn0 -
M tube
Glenn,
Can you clarify the term "chassis change" for me?
al0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 941 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
