hot water baseboard heat
Paul_36
Paul_36 Member Posts: 1
I just fixed a sauter joint on my baseboard heat. I need to bleed the baseboard at the boiler. starting from the bottom. I have a ball valve the a draw off valve. above that on the feed line with the pump there is a ball valve shutoff. How do I bleed the air out of the system????
