Residential Recessed Radiator Valve
Fran_3
Member Posts: 1
My house was built in the early 40's with recessed radiators. To have the valve fit properly, I need a valve with a stem slightly smaller than the standard 1/8".
Or can someone recommend a 'fix' to this problem.
hoffman 500
if you are talking about an air valve, a hoffman " 500 " might solve your problem0 -
The pros here are very accomodating, but a photo or two might help them respond.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
