buderus R2109 T T Help
RoosterBoy
RoosterBoy Member Posts: 459
  • S Ebels
    S Ebels Member Posts: 2,322
    The 2109
    In my experience has been nearly bulletproof. It has, if memory serves me right, a fuse to protect the low voltage innards. Shouldn't be a problem.
  • RoosterBoy
  • Joe@buderus
    Joe@buderus Member Posts: 165
    R2109
    The R2109 and R2107 are quite reliable, but voltage shorts can cause some issues. I would suggest putting a jumper wire on the "T T" terminals before hooking the thermostat wires to them. If the burner circuit doesn't pull in when jumped, then the module in the R2109 is shot. Do not replace the whole control! The R2109 has a seperate module for the low voltage. Please give us a call on Monday if you need any assistance or the part number of the module. 1-800-283-3787.
