Getting baseboard to heat all the way across
Chris_39
Member Posts: 1
we have a 1920s house with one-pipe steam heat. About 15 yrs ago previous owners bumped out the kitchen, installing a baseboard unit in place of original radiator. Unfortunately by the time we moved in the baseboard never got any heat. At the end of last season we had the boiler replaced and contractor repiped the baseboard--changing it to two-pipe instead of one. It now gets heat, but much more slowly then the rest of the house and never all the way across, by the time thermostat turns the boiler off the kitchen's still cold.
The baseboard has an adjustable air vent which is wide open. I've been gradually adjusting the air vents on other radiators, closing them more each day so that the baseboard is first to heat up instead of last. This isn't seeming to have much effect though.
Anything else I should try before calling my contractor to take another look? System is running beautifully otherwise.
Thanks!
Thanks!
What happened.....
when he changed it to two pipe? What did he do with the return line from the baseboard? How is it piped into the system? Pictures???0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
