In floor with domestic hot water
Greg_24
Member Posts: 3
Is there an easy way to set up in floor headers to get the air easily? Also when the in floor pumps are running from a call for heat, should the main pump always be running with them?
In floor with domestic hot H20
Is there an easy way to set up in floor headers to get the air easily? Also when the in floor pumps are running from a call for heat, should the main pump always be running with them? I am using a 4 way mixing valve for the in floor that has its own outdoor reset curve.0 -
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
