infa red thermometer reccomendations
TGO_54
Member Posts: 327
reccomendations for an infa red thermometer - the point and shoot type. I need something durable, accurate, and simple to use. Have one you love? Have one you hate? let me know.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=278&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Raytek
I have an ST60 and love it. Get one with a high distance to spot ratio. Having 30:1 is much better than 8 or 12:1 otherwise you have to get 3 or 4 times as close to measure things. They are all super simple to use, and even the ones with extra features don't make them harder to use, just more versatile.0 -
the ray tek is good for me....
However hot rod has this like super delux ultra cool one that tkes a area wide picture...i was into getting one of them it would be the deal however i sorta misplaced the thread he gave us for it..some where in Canada i think.0 -
Usage Warning.
I have a Raytek and several others too. They all work fine.
The thing to remember is that any IR thermometer is very in-accurate on metalic surfaces due to low emissivity of metal. To measure something like a copper pipe, you need to either paint it or stick a paper label on it to target or you will get a much lower than true temperature. The color of the paint or label makes little differance.0 -
Emissivity
Adjustable emissivity on the ST60... Another reason that's my recommendation.0 -
But you need to know the emissivity to adjust it. That's why I always use a label or paint.0 -
Thanks for all the replys - I guess I'll be looking at Rayteck
That's just a cheapy. Here is the one that I use:
http://www.flirthermography.com/cameras/camera/1063/
$30,000.
Ron0 -
infrared camera
saw an article the other day that said that these new digital cameras are sensitive to infrared. all you need to take infrared pictures is a filter. no personal experience. bob0 -
Or any videocam...
Any videocamera that has night shooting capabilities. That isn't exactly useful for measuring specific temperatures although you could go outside of a house on a cold dark day and get a good idea of where the heatloss happens.0 -
An infrared camera is totally different from a thermal imaging camera. An infrared camera (or infrared film) can only see "heat" that is over about 1000 degrees. It is really only looking at reflected infrared light that is coming from other sources. Not usefull for HVAC work.
Ron0
