Need equivalant peerless replacement .
Bernie Castonguay
Member Posts: 2
Need equivalant peerless replacement. Existing steamer is an American Standard,AMERICAN ARCOLINER M# WO154T SERIES 1BTJ1 360 STEAM 580 H2O 1.5 GPH. I've already checked the BEACON book 1959&prior. Also is the 360 steam # based on square feet of radiation? Boiler footprint is 22"w x 26"deep with an 8" flue.
If the existing boiler is sized right
the Peerless EC 3 section has 3 different sq. ft. steam ratings ( depending on the nozzle size ) and 360 falls right in the middle of them . Perfect match to increase or decrease the load if needed . Yep , it's based on square feet of radiation .
To be sure about the connected load , I would measure up the radiators and make sure the boiler is the right size .0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
