Not HB... but a nice little install ( milne)
ScottMP
Member Posts: 5,882
Chris A. did this nice little Buderus replacement boiler. He remembered to take before shots ( which I usually forget ).
I had told these people last Feburary but they waited untill October to call me :(.
Before shots ...and after
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Scott
A quick buderus replacement job.
Nice Clean Job, Question
What is above the boiler in picture 004? It looks like a old steam to hot water heat exchanger, was this job ever steam or gravity?0 -
Dale
Not sure what you are looking at, but in the new shots there is an old steel pipe near the chimney. This was no doubt a over flow from a expansion tank in the attic.
In the before shots there is a side arm tankless HWH that was out of service. They have a gas HWH around the corner.
Thanks for the comments
Scott
It was the side arm tankless that I was wondering about. Every old basement a little museum.0 -
Some wallies
have asked in the past "what's an everhot" the red gizzmachi on the side of the boiler is an everhot. All copper heat exchanger good stuff. bob0 -
Good work Chris
Attention to detail , even on the smaller jobs is what separates the cream from the crop . I like the gages on each return and keeping the piping away from all the serviceable areas . Do you find it harder to change the pumps when they're that high ? Keep the pics coming guys .0 -
Ron,
As long as there are shut-offs on either side, it's no prblem. The basement ceiling is only about 6' high, and those pumps are just above eye level. Thanks for the kind words. Chris0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
