cleaning oil furnace blower wheel
joeIDIY
joeIDIY Member Posts: 1
Please advise of solvent to use for cleaning blower wheel and housing for oil furnace. Cleaners for automobile use seem to hang around and stink up the house.
  • lchmb
    lchmb Member Posts: 2,997
    well
    a rag, a brush and a vac do the trick. I don't like to spray anything in there. Only thing I do is oil the motor if it has a port...scrape out the fin's and vac it up..:)
    On a safety note, make sure you have the power off before you stick your finger's in anywhere!!!!
  • Leo
    Leo Member Posts: 772
    I remove the motor, use a bottle type brush on the wheel (the same size one I use for gauge glasses). If it is oily and needs to be cleaned with solvent then there is an oil leak that needs to be addressed.
    Leo
