Pex Tubing on top of plywood subfloor.
Robert O'Connor_3
Member Posts: 272
staple gun
Watts radiant sells them
just about everyone does
Pex on top of plywood subfloor.
What is the best way to attach pex tubing on top of plywood subfloor before pouring concrete over? I'm considering one-hole EMT clips or Wirsbo nail-on tube talons or staples. Any suggestions?0 -
I'm doing this right now...
...and I'm using Vanguard 1/2" (size depends on tubing) economy clamps (I think the stock # is CLE3). They work great are low profile, and I just screw them in with 1 5/8" coarse drywall screws. I got them online from a place called "mvsupply.biz." A bag of 100 is about $14. If you spend $100 or more at their site the shipping is free. My mistake was that I ordered only 5 bags when I bought my tubing (over $100), but ran out because I wasn't spacing them far enough apart (should be every 2-3 ft). Then I had to order a couple more bags and pay for shipping. Oh well. I couldn't find them anywhere else.
What type of pour are you doing? We're doing a portland cement based mixture (as opposed to gypcrete), and also stapled down 6-mil. poly before we installed the tubing. It's some work, but will help cut down on the cracking due to settling/bonding. Also, planning on a 1.5" pour. I'd like to hear what height others use.
Good luck,
Dun0 -
air baby!
Air driven staple gun. Crank up the compressor and let them fly. Stadler , Wisbro everybody has them I think they are mostly made by Senco
