seen it all now
lchmb
lchmb Member Posts: 2,997
After the entire post on a homeowner install I had the luck to go to one today. I was actually impressed with the appearance. Very neat and straight. Then I found everything else!! The customer had put the pump on the return, but having heard pump away, he reversed the pump. I then found the coil mixing valve 6" directly over the top of the coil. He only saw where it said 6 to 8 inch's. Not the mention of "below the coil". If that wasn't enough, he antifreezed the system, with how much, he doesn't know, and never installed a backflow preventor. You could smell the antifreeze in the tub. And if that wasn't bad enough, the chamber had collapsed do to the fact when he fired the unit he closed the air band's because it made it quieter!! The unit was plugged very nicely....oh my....I have a headache...
  • Bluenose_21
    Bluenose_21 Member Posts: 14
    nasty
    Don't know if you should be p*&ed or just laugh at the stupidity. Well at least he didn't just throw out the instructions.
  • lchmb
    he did
    asked for them...got the thousand yard stare. It probably didn't look good for me but, I laughed. I start the overhaul on the unit tomorrow...
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 733
    it is a sad state of affairs
    that puts homeowners in this terrible position. With the economy the way it is and people with just enough knowledge to be dangerous trying to save some money, this is not going to stop any time soon. Quite frankly, I don't see any good solution but to continue to try to convince homeowners that there really are some things that they just should not try to do. Saving a buck is just a natural inclination for a lot of people, myself included, but, I have to wonder how many folks do this stuff that don't come to the Wall??? Are they hopefully lucky, or are they the ones we sometimes read about in the "CO again" thread?
    When you have the opportunity to correct some of these really bad situations, I hope you can feel some satisfaction for what you have accomplished, and possibly prevented.
    Larry
  • mark_40
    mark_40 Member Posts: 65
    Satisfaction ... oh yea !
    it feels almost as good as the feeling i get when i can pay my overhead ......'cause i sold the COMPLETE job ... you are not gonna make a living cleaning up some one elses mess
