steam
BIG S
BIG S Member Posts: 12
Okay,i have two dry return,above the water line the vents are Durst Corp.A883 3/4x1/2 straight steam vents.There are also two main lines that run off a 4" main an the reduce to 1 1/2 pipe both pipes have tee's;now the one that gets hot has a plug in the tee,the one that dosen't get hot,has the same kind of vent as the returns,but it stops heating in the four inch pipes,heats not making it to the reducer which is past the riser on the on the way to the H.Loop.So this makes 3 linse vented before the water level,an one pluged above the wt line.Pressuretrol is set to 3/4 in cut diff is about 1 7/8.How is this a vapor system,if the vapor parts are removed ?
