Flow Control Valve Dripping on end radiator in the loop...how to
My wife noticed wather inder one of our radiators and found that water was dripping from the flow control valve. It looks like there is some rust build up on the back side of the valve and turning it to close it has no effect. It seems as if the turning is not closing anything off in fact.
Whats the best way to proceed? We stuck a pot under it. Should I get a professional or is this something I can do.
  • Chris Horn
    Chris Horn Member Posts: 3
    Clarification
    The leak is under the end radiator in the loop where there is a small twistable wheel coming out of the pipe right next to the floor. I think thats called a flow control valve but i might be wrong...
  • Chris Horn
    Temp Fix
    I managed to get in there with some needle nose pliers and tightened the packing nut and that seems to have done the trick.
  • bob young
    bob young Member Posts: 2,177
    sounds like a balancing cock
