iron to copper
C.Hall
Member Posts: 2
Is there a rule of thumb to determine where to make the switch from threaded iron to sweated copper lines when piping out from a new, in my case Tarm, woodboiler? Simply cost of materials? Or some technical advantage?
Like they say with bicycle frames...
Steel is real! The threaded iron piping is better at handling the expansion/contraction cycles over the long haul. Copper can look nicer and be easier to cut and connect. The price factor depends on too many variables to say.0 -
On some
boilers the jacketing prevents you from getting a wrench on a copper adapter right at the boiler tap. In this case a snort, or short, steel nipple with a copper FIP adapter screwed on works fine.
It's nice to se a boiler piped in all threaded black pipe. A professionally piped iron job is a sight to behold! Swing ells allow you to straighten up boiler taps that are crooked, and allows expansion movement.
Copper seems to be more common for hydronic systems, these days. A bit easier to work, in large sizes, if you don't have a pipe machine setup. Also easier to add additional tees down the road. Especially if you own a T-Drill
hot rod
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
