cleaning a steam heat system
jimmy_3
Member Posts: 6
About 3 years ago i had my boiler replaced. This year bfore i fired it up for the first time, i drained as much water as i could from the returns. It still seems quite rusty, im sure it's from the older return line. what's the best method or chemical to put in the boiler and clean the rust out. Should i flush it on a regular basis? I've heard about using vinegar is this true?
Use about
> true?
a pound of TSP per 100,000 BTU's and put it in dissolved (or mostly dissolved) in red hot water via the pressure relief valve. Boiler it until the riser is too hot to thold you hand on.
Drain it and rinse it and put it back on line for an hour. If that first shot doesn't make the water clear, do it again.
The gage glass may need to be blown down or cleaned with a brush.
Good luck.
Ken
Use about
Good luck.
Ken
tsp?0 -
TSP =
Trisodiumphosphate. Available at most local hardware stores.0 -
and not legal in many areas
watch your hiny. Mex masonry cleaner works really well too. Mad Dog
Anybody ever try
That "TSP" substitute that I see all over the place?
It's in a liquid form, but I can't seem to find ingredient listings...
MEK is, IMO, more wicked than TSP.0 -
Indeed
TSP is not legal in this area. MEX is what I choose as well. Have heard of an "environmentally friendly" TSP product. Never seen it though.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
