\"A\" Dimension
Steamhead
Steamhead Member Posts: 17,630
do you have now? Have you had trouble with water backing up into the mains? If the present "A" dimension works, you should be OK.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Consulting
  • Dick DeAngelis
    Dick DeAngelis Member Posts: 12
    \"A\" Dimension
    I have decided to replace my pre world war II boiler in my one pipe steam system. I think I have a pretty good heating man. However I am concerned about the "A" Dimension. I don't have enough head room in the basement from the water line to the Main to get the 28 inches that is necessary. Is their an alternative?
  • Jacob Myron_15
    Jacob Myron_15 Member Posts: 4
    A dimension
    You only need 28" if the boiler is over 100,000 BTUH output.
    Under 100,000 BTUH 14" will do fine.
    If the boiler is prewar2 your new boiler will a bit lower than the old one so you will gain some inches for the dimension A.
    Jake t
Welcome
It looks like you're new here. Sign in or register to get started.
