two pipe system / severe hammering
I HAVE A 2 PIPE STEAM SYSTEM, OLD STYLE (EARLY 1900'S PLUMBING), WITHOUT THE STEAM TRAPS ON THE RADIATORS. A LOCAL PLUMB / HEAT COMPANY INSTALLED A NEW WEIL MCCLAIN 300,000 BTU STEAM BOILER INTO THE EXSISTING PLUMBING 3 YEARS AGO. I HAVE OWNED THE HOME FOR A LITTLE LESS THEN A YEAR..... I AM HAVING A PROBLEM WHEN THE BOILER SHUTS DOWN, I GET EXTREME WATER HAMMER. I HAVE CHANGED OUT THE MAIN BLEEDER AT THE END OF THE LINE, FLUSHED THE BOILER MANY TIMES, I EVEN HAD SOMEONE DOWNSIZE THE HEAT APPLIED TO THE BOILER BY PLUGGING SOME OF THE HEAT TUBES ON THE GAS RACK. TRIED EVERYTHING I KNOW TO STOP THE HAMMERING, WITH NO LUCK. ANY ADVICE WOULD BE GREAT.
  • Terry_10
    Terry_10 Member Posts: 20
    Two pipe system/Severe hammering
  • Thad English
    Thad English Member Posts: 152
    hammerin'
    Go to the Books section of this website and order "We got Steam Heat", by Dan H. Read it and in there you will probably find the source of your problem as well as learn a bit about the beauty that is steam heat.....
  • Guy_5
    Guy_5 Member Posts: 159
    Hammer
    I would look into the pressuretrol setting. Is there a possibility that the boiler is shutting down on pressure and the banging that you are hearing is a product of that?
    Guy
    Steamhead Member Posts: 18,210
    Is this an early Vapor system
    or does it have two shutoffs and an air vent on each radiator?
    Consulting
  • paul sr
    paul sr Member Posts: 39
    is the boiler surging violently in the gauge glass? maybe the installer didnt add boiler surging treatment and skim the boiler. or maybe there is water getting trapped in improperly pitched feed pipe
  • Terry_10
    Two pipe steam system
    Tom, I'm currious. It sounds like we have very simular systems, only mine is 50,000 btus. larger. I'm interested in how many burners were removed from your boiler, have you seen much benift and do you have any issues with having that done.
