Electric to Hydronic Conversion
Mark Anderson_2
Member Posts: 9
A potential customer wants to convert a house from electric heat to hot water baseboard. Is there a btu per foot rating for electric baseboard heat? I know I can convert wattage to btu's, but it may be quicker to go by footage if it is a standard output.
A potential customer wants to convert a house from electric heat to hot water baseboard. Is there a btu per foot rating for electric baseboard heat? I know I can convert wattage to btu's, but it may be quicker to go by footage if it is a standard output.0 -
Not really....
Many times it is 250 Watts/foot, but I would NOT bet the business on it.
It is a single phase electrical load. Just multiply amps x volts x 3.4 = Btu's. Or it probably still has the nameplate tag on it - that will tell you right off.
Nominal Wattage guesses will put you in a very awkward position.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
