best indirect hw tank
jersey devil
Member Posts: 7
can any one give there advice on best indirect hw tank with taps on side.looking for about 30 gallon 40" high.most ive seen local are top taps.thanks
Buderus or SuperStor have side taps
Buderus would be my first choice.0 -
Viessmann
Vitocell-H 300, except it's 42 gallons and 26" inches high0 -
The best?
Doesn't the Thermomax series beats just about anything out there, hands down, in terms of heating water quickly in a very small package? I doubt that even the Triangle-Tube Phase III can compete with that much copper... I have to re-read the respective recovery rates to be sure though.
However, I doubt that you or your client need endless hot water in institutional quantities. Thus, I would have a look at the Triangle-Tube Phase III or the Weil-McLain (knock-off?) tank-inside-a-tank system. Many installers here have been happy with the Phase III line.
I chose to go with Viessmann due to the double-HX inside the Vitocell B-line. It makes hooking up a solar hot water system that much simpler.0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
