One-pipe steam question
Sam Dizney
Member Posts: 1
There should be no problem provided adequate insulation is added to the nipple.
One pipe steam radiator....
I am moving a steam radiator about 2.5 feet to the left of where it currently is. Can I run a black pipe nipple from the shut off valve to the rad ....obviously with the proper unions/connections.... without having any "Steam Problems"?0 -
maintain proper pitch and NO TRAPS.0 -
steam
In addition to piping the extension properly, make sure you don't get any oil or other contaminants into the system. A little bit of oil or dirt in the boiler will cause BIG problems.
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
