cool use or taco rmb
Weezbo
Member Posts: 6,231
the buderas is about +100 'away it services some 12' of baseboard convectors and 7 buderas panels:) we goin for constant circ and low water temp .on start up we flush and purge the system up to the valves ahead of the rmb...fired up the boiler ,filled the system...locked off the valves dump the water add propyline glycol jazz the whole thing back up.Alex and Fred went back to wire it all up today..i just,pipe , make it go and head back to my overwhelming work i am already stressing over.spinning in another pump block soon. will get a picture or two. however,i also have two trimmouts and an underground to do and possibly a roughin and a boiler install water tank and quite a few zones of radiant to lash up so..i am a bit perclipsed at the momment:).Oh I almost forgot! is opinion of my buddy wayne and i am in agreement that we should put a tube to carry away any water comming out of the microbubbler from the conrtol pannel of thr rmb. talk amongst your selves:))) seen that on like mad tv or something:)
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
