Pro-Press Problems
S Davis
Member Posts: 491
Anyone having problems with the threads on Pro-Press male adapters leaking?
I went to fire up a system today and had seven of eight one inch male adapters leak at the threads, they were teflon taped and doped before assembly.
S Davis
Apex Radiant Heating
S Davis
Dave I don't know about PRO - PRESS
but if you try Mel Rose teflon tape (the pink type) you won't be disapionted but it costs a good bit more than the cheap stuff.
A.J.
Kupetz's Plb & Htg0 -
press
no problems here,we do the same tape and dope,turn a little tighter?0 -
ProPress Threads
Yup, I have seen the same problem. I posted about it a few months ago. I tend to use single strand wick and pipe dope. Had a few 1-1/4" female adapters leak on a boiler start-up and just this past week had a 1" male adpter leak on a pump flange. We have only used the ProPress since April or May but others in our shop have experienced the same thing.
-Jared0 -
leaks on threaded connections
if lampwick is not used on all threaded joints for any system involving water and pressure , you will always have leaks. steel pipe will eventually rust up and seal but thats another story.0 -
Pro-Press
Well I got in touch with the Viega rep and he is comming out to the job site on monday to take a look, I will post the results, one thing I was impressed with is I called the Ridgid Rep and within 30 minuites had the Viega rep on the phone.
S Davis
Apex Radiant Heating0 -
in general...
use lots of teflon paste besides the tape - otherwise the tape tears when you screw it in and becodes inefective - or use lots of tape and spray it with liquid soap0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
