boiler installation
mike16
mike16 Member Posts: 1
I am installing a oil fired boiler with section for domestic hot water. I am going to put the pump on the supply side of boiler. Is it all right to put in line right on top of boiler? Because 3 feet out of boiler, the line goes into a valve which looks like something that will keep heat from generating into the heating loop while the boiler is heating for the domestic hot water. This valve has one output to main loop in house. The other side is a secondary loop and than it goes up to the aerating tank on back side of valve. Any comments if I put pump here would be appreciative.
Thank you
