Inexpensive BTU's
Andy_14
Member Posts: 121
I'm doing an area which the slab will not be enough to heat the building due to small area that pex can be put. Can anyone suggest inexpensive supplimental heat. I was looking at fan forced toe-kick units that produce about 10,000btu's for about $250. Anyone have another suggestion?
options
Andy,
Try a panel radiator and install a two stage thermostat so the panel will only run under extreme conditions. I think $250 is low for any solution, at least you will utilize the radiant as much as possible.
Steve0 -
Thanks for the reply Steve. I'll look into that.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 972 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
