Staged Peerless??
Steve_54
Member Posts: 1
Does anyone know if Peerless has any staging or modulation controls for their GM series Boilers?
What I'm looking to do is stage the output on startup as the startup loads are really pretty small but continious; and the flow through the system must be constant per the customers installation specs. (Changing the bypass or dp controller won't cut it because of the required flow rate of the equipment and their maximum heat up rates.) It short cycles and occasionally trips an external time delay based on minimum run time.
Peerless GM boiler - controls available
Peerless has several options available. You can call me for details or also checkout their website @ www.peerlessboilers.com
I can be reached at (717) 627-3868
Mike0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
