Gas Meter
Jeff_17
Member Posts: 99
Does the natural gas meter in my house regulate the pressure of the gas or does it simple measure the amount of gas used?
Meters do not
regulate pressure. The pressure is set by a pressure reducing valve (PRV) before entering the meter, if required. There are many low pressure systems here in Mass that do not need a PRV and may even require a booster pump.
This is my simple explanation and you will probably get more detailed information from "gas" people.
Just measures
The meter is just a measuring device, it does drop a little pressure since it's a type of air motor that uses the flow through it to make the dials turn. Almost all residential meters have 1/4 to 1/2 pound pressure gas in them although some have 2 psi gas. If there's regulation it's ahead of the meter. Where I am it's 20 or 60 psi regulated to 1/4 or 2psi.0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
